What's wrong with my Tek 2335?
jigshaw
China
Recently I got an old oscilloscope,it was an old type,Tek 2335.
But something wrong went with it after I took apart it and assembled it.
It had no display on the screen and a LED indicator lit on (as Fig1 shows).
I got explaination from its instruction manual that Chanel 1 & 2 var control is out of calibraed detent. (as Fig2 shows)
Anyone could tell me how to fix that?
Thanks a lot!
I have a 2235 scope. The center control (i.e., those missing knobs) must be turned fully clockwise to activate a switch, which makes the uncal light go out. Maybe the switch is bad?
John
Thanks for your reply!
Those missed knobs were turned off by myself ,I wanted do a clean for the front panel.
It should be turned fully counterclock.
That indicate went off now.
But there 's no display on the screen. I still need more work to fix it.:-?
What happens when you press "beam find" on the left ?
A new problem is that two test points on the board near the screen tube tail, only have a voltage of 5.3 V,which singed with "102V" orignally.(As figure A & B shows, test points are marked with red cycle)
But there is no so high voltage on power supply board.
You need to find a service manual to help fix this.
Check on Yahoo Groups where there is a very active forum of Tek users. Someone there is sure to have the information you need.
There was no display still when I pressed "beam find".Sure there's something goes wrong with the tube circuits.
That test point signed with "102V" only has voltage of 5.3V.
---------- Post added at 12:21 ---------- Previous post was at 12:19 ----------
Yes,a service manual would be very helpful.
But there's only service manual for Tek 2235 and only Instruction manual for Tek2335 on the Internet.
---------- Post added at 12:22 ---------- Previous post was at 12:21 ----------
Thank you.
Can you give their name?I found many Tek groups on Yahoo.
It sounds like you may have a HV power supply issue.
Here is one of the Tektronix Scope User Groups that Brian mentioned.
BigDog
---------- Post added at 12:54 ---------- Previous post was at 12:40 ----------
QService has your scope service manual for $12.49:
TEKTRONIX 2335 SERVICE MANUAL CD
BigDog
BigDog
BigDog
Well,the service manual seems too dear for me. This machine costed me only $30. But its manual costs $12.5.:-o
Dear jigshaw i have this service manual [ tektronix 2235]
  • Tektronix 2235.rar
I have the 2235 manual too, it's a common model but this is a 2335 which is relatively rare and a completely different design.
