littledog
Newbie level 5
I'm involved in an educational project and I want to design a logarithmic amplifier based on ua741. Following capture shows my circuit:
Diode is 1N4148
Resistor Value is 33Kohms
And the results in lab and simulating don't match the results using the following formula:
Vin= 6v
Vdd+=15v
Vdd-=-15v
Vt= 0.026 v
Is (Saturation Current = Reverse current) = 25 nA (I took from diode datasheet)
Even simulating results and lab results don't match.
Vin Simulating (Using multisim) ____Lab _____Formula
6v=> -0.552 _________________-0.523____ -0.231
5v=> -0.547 _________________ -0.516 ___ -0.226
4v=> -0.541 _________________-0.505_____-0.221
I don't know if I'm applying correctly the formula or if this is the formula I have to use.
Is there a way to check which parameters use Multisim to simulate ua741 or diode 1N4148?
Thank you very much in advance,
Diode is 1N4148
Vin= 6v
Vdd+=15v
Vdd-=-15v
Vt= 0.026 v
