Alexium
Full Member level 2
Greetings!
This is my first message here, but I'm reading the forum for some time now, and I'd like to thank you for the work you, guys, are doing here helping each other in the community, and - indirectly - other guys like me from all over the world.
I'm doing my diploma project. It should be a configurable coprocessor for PC. But - shame on me - I ran into a bit if a problem doing Ethernet MAC controller. The problem is I only have a quarter-finished simple controller as a reference. I can finish it, but it will take the kind of time I don't posess. Having realized that I grabbed two controllers from Opencores, but those turned out to be of no use to me: they have wishbone interface (which I don't want), and I can't make heads or tails out of it to eliminate the Wishbone layer. My project hangs in balance.
Thereby, I'm asking you for a simple implementation you could share. I only need 100Base-TX full duplex, i.e. no CSMA/CD.
Thanks in advance.
P.S. Sorry for my English, I'm only learning...
Thanks in advance.
