off grid error drc error
jalinmes
Junior Member level 2
u.s.a
Hi
I found there is one off grid error in the file i submitted yesterday. Can some one pls tell me what will happen to it?
They said the project is released for run and ask me to resubmit it asap.
I want to know what if i miss it, what will do with this off grid problem?
This trace wont be able to manufacture? or they will send it back and ask me to fix it ? normally how soon after the deadline, it will be fabricated?
Tks,
DFepends how much off it is. The direct consequence will be that the trace will not have the size as drawn. It will still be there but will be probably rounded up/down to the closest manufacturing grid which might cause it will violate other rules like minimum width or spacing.
The thing will still work but would no recommend to do it if you can fix it which is usually quite fast.
If it is a shuttle not final manufacturing I would say screw it.
Also you might sign a waiver so they will not complain - if something is shorted or disconnected you are on your own.
I would resubmit.
Fortunately the updated design has been submitted it again ontime, thank you.
