How to print an integer in VHDL
raghava
HI all,
How to print an integer in VHDL.
I am using following syntax.
report "Number of cycles taken = " & count_cycle;
Its giving error.
Can anybody correct it.
Added after 1 minutes:
Here count_cycle is variable.
I am afraid the message you type can be text only.
You're apparently refering to VHDL simulation. You should be able to find respective string conversion routines in textio package.
P.S.: I see, that report uses a generic STRING type argument, while textio.write uses the derived LINE type. It's not clear to me,
if they can be made compatible. Otherwise I would consult the simulator's user guide for suggestions.
HI Fvm,
Thanks for your answer.
In verilog we have $display("%d", 6);
In the same way how should I print in VHDL.
Here I have to print some variable which is stored with some integer value.
and **broken link removed**
Amr Ali
    raghava
HI Amar Ali and Frankliner,
Thanks for your answers. I am in desperate to know the syntax as I am in urgency.
Added after 3 hours 28 minutes:
HI all,
This syntax is working.
report "Number of cycles taken = " & integer'image(count_cycle);
even write() is also working.
Regards,
