How to print an integer in VHDL
raghava
Member level 2
HI all,
How to print an integer in VHDL.
I am using following syntax.
report "Number of cycles taken = " & count_cycle;
Its giving error.
Can anybody correct it.
Regards
Added after 1 minutes:
Here count_cycle is variable.
dmk
Full Member level 3
Bg
I am afraid the message you type can be text only.
FvM
Super Moderator
Staff member
Bochum, Germany
You're apparently refering to VHDL simulation. You should be able to find respective string conversion routines in textio package.
P.S.: I see, that report uses a generic STRING type argument, while textio.write uses the derived LINE type. It's not clear to me,
if they can be made compatible. Otherwise I would consult the simulator's user guide for suggestions.
raghava
Member level 2
HI Fvm,
Thanks for your answer.
In verilog we have $display("%d", 6);
In the same way how should I print in VHDL.
Here I have to print some variable which is stored with some integer value.
Regards
raghava
Member level 2
HI Amar Ali and Frankliner,
Thanks for your answers. I am in desperate to know the syntax as I am in urgency.
Regards
Added after 3 hours 28 minutes:
HI all,
This syntax is working.
report "Number of cycles taken = " & integer'image(count_cycle);
even write() is also working.
Regards,
