file reading problem in VHDL
raghava
HI all,
I am facing problems with file reading in VHDL. I am newbie to VHDL.
I am expecting answers.
Here is the code and error message I have got.
procedure PrepareInput is
variable inLIne: line;
variable int_text : integer:= 0;
variable index : integer:= 0;
--file file_in : text open read_mode is "../data/input/lena_64_64.txt";
--file file_in : integer;
type int_file is file of integer;
file file_in : int_file is in "../data/input/lena_64_64.txt";
begin
while not endfile(file_in) and (index<IR*IC) loop
--readline(file_in, inLIne);
--exit when endfile (file_in);
--read(inLIne, int_text);
read(file_in, pixelImage(index));
index := index + 1;
end loop;
file_close(file_in);
end PrepareInput;
Error message is ERROR: In process testbench.vhd:stim_proc
../data/input/lena_64_64.txt read error on type int_file
INFO: Simulator is stopped.
What simulator are you using?
1. Why do you not use the VHDL-93 file procedure:
file file_in : text open read_mode is "...";
2. The readline is necessary. Reading a file has 2 steps, first read the entire line with the readline function and next, break up this line (if necessary) and assign it to variables with one of the several read functions.
Devas
    raghava
HI Devas,
Thanks for your reply.
I am uising ISE 11.3 simulator.
I wanted to read a .txt file in which MXN matrix of integers (image raster data).
Should I have still readline and read command individually.
Now the new code is given below. Could you check it out. And moreover inbetween readline and read command, exit should be there or not.
Expecting your valuable reply as I am newbie to VHDL.
variable index_test : integer:= 0;
variable end_file:bit:= '0';
file file_in : text open read_mode is "../data/input/lena_64_64.txt"; --VHDL 93 syntax usage
begin
while not endfile(file_in) and (index_test<IR*IC) loop
read(inLIne, pixelImage(index_test));
index_test := index_test + 1;
end loop;
end PrepareInput;
You need always a readline and almost 1 read, as readline reads one line from the file and read gets a value from this line. When you have more than 1 value on the line, then you need more reads behind the readline, for example when your input file is:
9 4 3
2 6 2
You need 1 readline and 3 reads, the first gets value 9, the second value 4, the third value 3.
The exit is not necessary as the while ends when you reach end of file (or index has reached a value).
pixelimage(index) has to be declared. The read expects a variable, so you can declare it inside the procedure as a variable. From your previous post you declared it outside as a signal. Then you need to declare the pixelImage as a signal in the procedure parameter declaration and you can use a temp variable in the read and on the next line pixelImage(index) <= temp_var;
Devas
    raghava
HI,
I have to read MXN matrix from the input file.
M = number of rows and N = number of columns.
Then read statement should be put under for loop iterating for N times or what.
Here PixelImage is shared variable.
Could you modify the present code given below.
begin
while not endfile(file_in) and (index_test<M*N) loop
end loop;
end PrepareInput;
Well I would suggest to try it out. I believe that is the best way to learn a language.
If your input file has more than one value on a line, than yes you need more reads. In my previous example with 3 values on 1 line:
readline(....);
read(....);
read(....);
read(.....);
Sucess,
Devas
    raghava
HI Devas,
This is the code I have written now. read statement I have put under for loop running for IC iterations.(Which represents no of columns i.e no of elements in a row)
for i in 0 to IC-1 loop
end loop;
end loop;
Added after 4 hours 28 minutes:
HI all,
The problem got solved.
Thanks to Devas for your help. This is the final code
file file_in : text open read_mode is "../data/input/lena_256_256.txt";
begin
end loop;
end loop;
end PrepareInput;
