How to increase the output swing in CMOS LC VCO?
calculus_cuthbert
Member level 4
Hi
I have designed a CMOS LC VCO.
I want to improve the output swing of the VCO.
Pre layout simulations show that the output swing is 1.4 V (0.18u process)
But after laying out all the blocks the output swing drops to 0.8V peak to peak.
I would appreciate it if someone could help me figure out how to increase the output swing. Is it because of parasitic resistance that the gain is lowered?
The ground plane in my design is in the lower most metal.. should i change it to a metal layer with lower resistivity?
vco lc
In spite of going into speculation, I would recommend you to find effective parasitic R's added to each branch. U can do IR drop simulation.
Thanks,
calculating cmos lc-vco
are you using minimum width traces and minimum number of vias? i did an extraction with QRC the other day using minimum sized traces/vias for power/ground, and saw that vdd loses 50mV from bondpad to m1 (8 metal process).
vco post layout simulation
b4 going for IR drop analysis, U can try this simply,
make u r simulator to print out operating point information(node voltages) at different time points.
then compare the values between prelayout and postlayout runs.
for exp: compare node voltages printed by your simulator between pre and post layout simulation @ time 0n
This will help to find wht/whr it wnt wrong :)
Hope this helps.
Thanks,
lc vco swing
I'm also facing a similar problem i.e. discrepency between pre & post layout simulation result of a Class C vco. The tail current jumps to twice as much. Any idea how to debug the issue?
lc vco swing over vdd
you can check the quality factor of the coil after extraction and compare before extraction , it seems that the quality factor of the coil drops significantly after extraction ,
Re: CMOS LC VCO
check your current!
Reactions: ninahz
    ninahz
Re: lc vco swing over vdd
why Q factor will reduce the output amplitude?
DO you have parametric values for all of the following?
Layout details are critical.
