lsimeon
- Joined
- Aug 1, 2008
- Messages
- 53
- Helped
- 3
- Reputation
- 6
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Philippines
- Activity points
- 1,595
Power Management circuit
hi,
i am currently reviewing the design of our company's power management circuit; for your background in our design - our power management is composed of different blocks for 5V to 3.3V then 3.3V to 2.25V then 2.25 to 1.8V these blocks are used to supply the different VCCs of our cores inside our product, and here is what I found:
--> there is a significant resistance across each voltage sources for example across the 3.3V (disconnected from the load) there is a resistance of 5ohms but this is subjected to supply as high as 5A...
the question is, is the 3.3V supply capable to handle this amount of load (5A)?
on my point of view, this is not valid because this voltage supply is limited only to a maximum of (3.3/5) 660mA current which is by considering its internal resistance of 5ohms...
need your opinions...
thanks....
regards,
Simeon
hi,
thanks....
regards,
Simeon
