sanddune008
Newbie level 6
Hi All,
Prj Description:
I am designing a hub which receives i/p's(max of 4 inputs) from actuators and slaves connected to the hub(output). When an actuator input is received Master(Hub) will process it and sends a common command to all the salves connected to its output....based on the command each slave will do the necessary.
MAX485 is connected to the UART.
Now the problem is the slave receives data which is noisy and hence displays junk day to the LCD........
I am sending "Hello world" at baud rate : 384000
Can anyone please verify my schematics.....which is attached.
Also attached is my slave input to micro controller (yellow w/form === at Pin R0 ) and micro controller output to MAX485 (blue w/form)......
Thanks in advance...........
Prj Description:
