What is difference between ron and 1/gds?
peterlau1984
Junior Member level 1
ron gds
Dear all,
I found the statement in cadence document that "ron" is on-resistance, while "gds" is common-source output impedance. Both of them are operating point parameters. What is the difference between ron and 1/gds?
Furthermore, we usually caculate with the parameter "ro" during design, which is equivalent with "ro", "ron" or "1/gds"?
Thanks!
cadence ron
sorry, it is my typing error. gds is common source output conductance.
I found the statement in cadence document that "ron" is on-resistance, while "gds" is common-source output conductance. Both of them are operating point parameters. What is the difference between ron and 1/gds?
Thanks!
mos gds gm
In my available literature (Gray/Mayer, Razavi), ro is the usual term for output impedance of common source amplifier. 1/gds is just the same, to my opinion. ron, in contrast is the impedance in unsaturated operation (using the transistor as a switch, @ Vds = 0). It's surely much lower than r0, cause the values are representing completely different operation points.
cadence ron or 1/gds
I agree with FvM "ron" is the impedence when mos is in linear region and "ro"="1/gds" is the impedence when mos is in saturation...
what is a difference gds gds2
How about if transistor works in subthreshold region? How much would be the output resistance of the trarnsitor?
Thanks.
1 / gds
Thanks.
ro(subthreshold) = n*Vth/Id with slope factor n = 1.5 (+/- 0.3) depending on Vds
gds=1/ro
Thanks erikl,
So assuming Vth is thermal voltage, are you saying that the ro is 1/gm? Is there any reference for this equation? Is n=1+Cdepletion/Cox? How does n depend on Vds?
Thanks.
common source gain gm gds
a.zar said:
Thanks erikl,
Correct
Yes
/1/ Behzad Razavi: "Design of Analog CMOS Integrated Circuits", McGraw-Hill Int.Ed. 2001 Chap. 2.3 p. 27/28 . The slope factor "n" here is printed as (grec) "zeta"
/2/ Christian C. Enz, Eric A. Vittoz: "Charge-based MOS Transistor Modeling", Wiley 2006 Chap. 5.1.1.3 Approximation in weak inversion, eq. (5.20)
To a first approximation, yes; Exact: n = 1 + (Gamma(b) / 2*sqrt(Psi(s))) /2/ eq. (3.34)
Gamma(b) being the substrate modulation factor /2/ eq. (3.30) ,
Psi(s) is the surface potential /2/ Fig. 2.2
S. /2/ Chap. 3.5.1 eq. (3.31)..(3.37) and Fig. 3.7 & 3.8 (p. 21 ff)
Cheers, erikl
what is gds transistor parameters
Thanks a lot.
Added after 2 hours 52 minutes:
Hi again erikl, just another quick question: With rout=1/gm, what would be the gain of the transistor? Is the equation gain=gm.rout still valid?
Thanks.
difference between gds and gdsii
for me , i think, if the device is working in deep linear range, the Ron=1/gds, but if working in saturature range, you can not say that, you can see small signal model, the r0=1/gds
peterlau1984 said:
Dear all,
Thanks!
ron equation of cmos
a.zar said:
Thanks a lot.
Thanks.
If rout=1/gm then gm.rout=1 . gain=gm*Rload
cadence transistor gds ron
some times Ron is used for the triode case, and 1/gds is also called ro, but depends on the text book convention. sometimes, instead of ro, they just use rds as well
gds pmos formula
What cadence call ron is actually the On impdeance of the transistor.
Say when you need it as a switch, then you should make it work it in triode reqgion. There the dc output impedance is "ron".
Whereas the 1/gds is the small signal output impedance of the transistor and should be seen when the device is in the saturation region.
Reactions: Nadida
    Nadida
Re: gds pmos formula
I have simulated this for a NMOS, where ro=(1/gds) and ron is from device parameter, clearly both are not same!
... ro=(1/gds) and ron is from device parameter, clearly both are not same!
I think ro=(1/gds) is the small signal (differential) output impedance, whereas ron is the DC output resistance, as sanjeeb stated above.
Reactions: anhnha
    anhnha
