s_cihan_tek
Full Member level 2
Hi all,
I need to use the on chip 10-bit ADC of a microcontroller. In order to get real 10 bit accuracy i need to filter the signal before applying to the ADC input. The question is:
Can an active filter remove/reduce hf noise caused by the circuit, while the supply voltage/ground of the filter circuit is noisy?
The circuit is on a breadboard. I used bypass caps where necessary and paid attention to current return paths but couldn't be able to reduce the noise level of the supply/ground below 1mV. I guess that i need to get rid of the supply/ground noise in order to make the filter do its job. What can i do to reduce the noise and make the filter function properly?
Thanks in advance
Thanks in advance
