What is the baud rate at which PC communicates ?
Re: baud rate
how do we do serial communication with pc , say i want to display 10 on my computer, how do i do it ,
baud rate
1if u are using PIC microcontroller then go these step
1.set baud rate and put data in buffer
Re: baud rate
Hi My Frinde
the baude rate is the speed of serial data transfer and you can configuare pc at any baude you need from 300,600,1200,2400,4800,9600,19200,... etc
don't forget to configuar the same baue rate at micro and pc
now...tell me your micro and compiler ... and tell also the pc software then i'lltry to help
Re: baud rate
if you asking to the meaning of the boud rate: the boud rate means the symbol rate as by digital modulation the symbol can contain more than one bit like the QPSK (Quadrature Phase shift Keying) the symbol has the information of two bits & hence the boud rate = bit rate/2
the advantage is to save bandwidth
best regards,
Rania
Re: baud rate
you need to set up the baud rate of the controller same as of the computer, secondly if you are using Hyper terminal the you need to send the data in ASCII format, you need to see the list of ASCII for 1 and for 0, It means you need to send the data in two bytes.
regards
