foxabilo
Member level 3
- Joined
- Jul 16, 2007
- Messages
- 67
- Helped
- 13
- Reputation
- 26
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Derby, England
- Activity points
- 1,886
Hi all,
Ok so here I am doing exactly what everyone else is doing and that is mainly building programmers/debuggers thanks to the hard work from all the usual suspects on the forums.
One thing I did notice was quite a lot of talk about getting Vpp from USB +5v and the use of Maxim and Ti parts that are either impossible to get samples of or cost a fortune, inductors are a pain in the bottom, everyone wants a charge pump one, but they all need oscillators and that seems to be where everyone gives up and gets a maxim/Ti chip AND a bunch of capacitors.
Welp here ya go, I know a lot of the more seasoned users here will recognise the major parts of this circuit but I have not seen this design any place else on the net and its perfect for generating Vpp at a very small mA load such that Vpp presents.
All the bits are bog standard stuff I had laying about stuck to the carpet, in my bed, in draws ment for knifes and forks and other places where electronics end up if you love the art.
As you can see from the occiloscope plot Vpp reaches 11v in under 10ms and seesm to run at about 11.6-12.4 volts stable in the real world depending on the tollerence of your components, I included a 10K pull up (R5) from 5v to simulate a typical load on Vpp which you can remove or keep depending on what you want to do with your Vpp. But remember that the charge pump requires a load to function, largest value for R5 realisticaly is 250KΩ, but better is 100KΩ
I've tested the design on the bench and it seems fine, but I have not used it to program a pic with yet as that'll come later, but its such a simple & cheap design any issues should be easy to work out.
(worst case ripple at Vpp is 154mV, you could reduce this with a larger value C5, with C5 at 10µF, time to 11volts is 39ms and ripple goes down to worst case 7.5mV )
(Changing R1 and R4 from 330Ω to 33Ω gives more mA output but is at the limit of oscillator stability(according to the simulation anyway), play with the values if you need more power)
Edit: R1 and R4 at 100Ω seems to give the best real world performance
**broken link removed**Ω
