logic and behavioral synthesis
shiv_emf
Advanced Member level 2
Hello
i want to knw basic difference between logic and behavioral synthesis..
n whr can i find this information ?
thanq
Shiv
Logic Synthesis is a process by which an abstract form of desired circuit behavior (typically register transfer level (RTL) or behavioral) is turned into a design implementation in terms of logic gates. Common examples of this process include synthesis of HDLs, including VHDL and Verilog. Some tools can generate bitstreams for programmable logic devices such as PALs or FPGAs, while others target the creation of ASICs.
Behavioral synthesis transforms a behavioral HDL specification into a register transfer level (RTL) specification, which can be used as input to a gate-level logic synthesis flow. Behavioral optimization decisions are guided by cost functions that are based on the number of hardware resources and states required. These cost functions provide a coarse estimate of the combinational and sequential circuitry required to implement the design.
    shiv_emf
can u provide some material on this aspect !!
thanks for clear explanation vlsi_whiz
shiv
hi
for more details u can refer Douglas Perry or J.Bhaskaran book.
regards
shraddha
    shiv_emf
shraddha said:
hi
regards
shraddha
title of the book??
shiv_emf said:
shraddha said:
hi
regards
shraddha
title of the book??
Hi
The Title of the Book is " VHDL Programming by Example " by Douglas L. Perry.
