PROGRAMMING AND INTERFACING THE 8051
Fragrance
East Of Earth
multipage tiff djvusolo
HI ALL,
Here is the source code from the book of programming and interfacing the 8051 by SENCER YARALAN
hope this will be help, this is the hole cd of the book source code attach with the back cover of the book last day i got a photo copy
regards
Fragrance
can you upload the book..?
(8051 programming)
    V
Re: can you upload the book..?
(8051 programming)
Hi
Yes i want to upload the book but i need help from friends This is a photocopy but the copy is on high grade paper so quality is good i wnat to know the following things i scan the book in sequence like jpg1,2,3 and so on.
does any kind of software that can made a postscript file for adobe in sequence to make pdf once some body told me about this i will take one week to do that to up load it.
regards
Fragrance
Better use DjVu format. Freeware DjVu Solo 3.1. can make very fast batch conversion from set of .jpg files to .djvu format.
Ace-X.
Ace-X.
Where dl it?
Also you can try 5D pdf creator.
use acrobat writer to print each page as a PDF file. then insert each file as a page into the file that collect all
Hi
any news about this nice book ?
bye
mgajo said:
Hi
bye
the book was under scaning process once it completed i will upload it
3hundred + pages to scan huge job and work
    V
Plz, can you upload the first part of this book ? .... Then upload the rest when you finish
Thank you
The system uses SAB by siemens micro, not a basic 8051 chip
Hi Fragrance,
Do you have fininshed the book yet?
Upload anything like first chapter at least :)
Thanx
I am benefitted by this Book
-Rajesh
the abbyy fine reader software works good with high quality scans, especially files saved as multipage tiff files. It can also group files togher and convert to pdf.
hi all
where i can get the book.
can any body tell who is the publiosher of this book i mean to say wheter it is patrience hall publication or any other
Programming and Interfacing the 8051 Microcontroller (Paperback)
by Sencer Yeralan, Ashutosh Ahluwalia
Paperback: 328 pages
Publisher: Addison-Wesley Pub (Sd); 1st edition (January, 1995)
Language: English
ISBN: 0201633655
