davyzhu
Advanced Member level 1
I want to run perl command with dynamic argument in SystemVerilog. And I use Cadence IUS583.
When I try to pass a string to $system(), the ncvlog said "Using String without index is not supported in the given context."
The code I write like below,
string perl_cmd_str = "";
$sformat(perl_cmd_str,"perl ./perl/test_opt_file.pl -a %0d -b 4", data_a);
$display("string is %s\n", perl_cmd_str);
$system (perl_cmd_str);
Any suggestion on how to input string to $system()?
Thanks!
Davy
Thanks!
Davy
