What exactly LDO stands for ?
safwatonline
EGYPT
LOD
i wanna know what LOD stands for ?
p.s:"i dont mean LDO or LDD "
Re: LOD
LOD Stands for Length of OD Region.
The device Performance is depends on source & drain area regions.
the device performance is Vt or Id is impacted byLOD effect.It is due to different mechanical stress induced by differnt od Regions.
These area r Represented by SA &SB in R&C extracted files.
    safwatonline
LOD
hi, what is OD dont tell me O and D.
thnx
Added after 57 seconds:
i found in some site that LOD is the length of drain is that correct?!
Re: LOD
LOD is Represented by two parameters SA & SB.
SA & SB are the distance b/w the gate and the OD region.
SA & SB will affect the drain current of MOS.
LOD stands for length of OD (oxide definition). OD can be either source or drain.
SA & SB are the parameters that Represent area of source or drain region.
    safwatonline
LOD
ok , I THINK LOD is length of diffusion not oxide definition
thnx anyway
Re: LOD
Why dont you ask Dr. Hani Fikry from your college :D ?
LOD
i try to serach LOD info from the NET but can't really get a good one.. any one can suggest a good source on it...
i think LOD stand for "length of diffusion"...
any help would b grateful...
thank you
regards
sp
