What is the difference between "AC magnitude" and "Amplitude" in Cadence?
qiushidaren
Full Member level 2
BME??BFE
What is the difference between "AC magnitude" and "Amplitude" in Cadence, thank you in advance!
bme bfe
Amplitude is used for a periodic signal like clock, thus frequency dependent.
AC magnitude is used for frequency independent composites such as device noise or spurious or floor noise.
ac magnitude
I still can't catch you, amplitude is frequency dependent? I have never heard of this!
Re: AC magnitude
You can check Cadence Design Manual and Help on AC response and characteristics.
It explains there.
    qiushidaren
Re: AC magnitude
It explains there.
Ok, thanks for your suggestions!
Re: AC magnitude
what a pity, I can't find a Cadence Design Manual in my computer, so can someone else explain some details about the difference between AC magnitude and Amplitude in Cadence to me? Thank you in advance!
AC magnitude
Hi,"AC magnitude" is used in "ac" analysis and it is an ac small signal amplitude.
"Amplitude" is used in "tran" analysis and it is a large signal amplitude.
Re: AC magnitude
Thank you so much, you really help me a lot!!!
