A, B, C and AB amplifier operating points
Hammer111
Junior Member level 3
Can anyone tell me if this diagram is correct.
My interest is in those points which I put there are they correct for amplifier classes respectivly?
Hi, Your correct.
A is in the middle.
AB is an point between A and B. can be anywhere !!..
B is just at the point of conducting
C is at 0.
Paul.
As far as I know
A is in the middle.
B is at 0.
AB is between and
C...
Here is a picture..
I checked now and the diagram I attached in my last message is correct..
So i guess yours is wrong...
Peace...
    Hammer111
Yeah, I doubted for my diagram cause of Ic current of B and AB class and made a new one.
Thanks for help!
Class A
The amplifier conducts current throughout the entire cycle (360º). The Class A design is the most inefficient and is used in low-power applications as well as in very high-end stereo. Such devices may be as little as 15% efficient, with 85% of the energy wasted as heat.
Class B
The current flows only 180º for half the cycle, or two transistors can be used in a push-pull fashion, each one operating for 180º. More efficient than Class A, it is typically used in low-end products.
Class AB
Combines Class A and B and current flows for 180º to 200º. Class AB designs are the most widely used for audio applications. Class AB amplifiers are typically about 50% efficient.
Class C
Operating for less than half of one wave cycle (100º to 150º), Class C amplifiers are the most efficient, but not used for audio applications because of their excessive distortion.
So it is chart 2.
