How to properly do hardware delay
Help
Advanced Member level 2
Anyone can help me to check the simple code (the program is work).
The problem is when i using Keil to simulate the result is.. 1.029805sec at 1000 looping but...when practically is not ~1sec (it take more then few min).
So, i change it to 1 at DELAY_T0_Wait(1); then in practical the result nearly to ~1sec.
The hardware crystal is 11.059MHz.
Can anyone tell me why?
Thank
Re: Hardware Delay
Hello
This is a wrong way to do hardware delay!
You should set the timer for periodic inerrupt who increase a long type variable
TimeValue = TimeValue +1;
when you wish to start a delay you need to save this register value + the delay
period.
Temp = TimeValue + Delay;
for testing create an if loop who read the variable and coper it to the one you saved once the value are equle or large then -> the delay is over
DlayFlag = 0;
Temp2 = TimeValue;
if(Temp >= Temp2)
DlayFlag = 1;
All the best
Bobi
    Help
Re: Hardware Delay
Hi Friend,
Very happy you can explain to me but i still got a bit blur blur.:cry:.., please can you help me to modified my code. So, i can study/try from the code, if i still not understand it so we come and discuss more further can we?
Thank You
Re: Hardware Delay
I can't see anything wrong with this code (from Chapter 6: "Meeting real-time constrains", Embedded C), even if it doesn't use interrupts ..
Can you post the compiled code which you try to use in real microcontroller ..
Regards,
IanP
    Help
Re: Hardware Delay
hi,
I am using that i post it to run it in real microcontroller. Only the different with the code is.. the book is given DELAY_T0_Wait(1000); then i change it to DELAY_T0_Wait(1); because if i using the book given value i can't achieve ~1sec in real microcontroller.
Do you got any idea??
Thank You
Re: Hardware Delay
I checked the HEX file from your ZIP, disassembled it and couldn't find any errors ..
Then I tested your code in 87C52 micro and as it is I have 1.2ms square wave on pin 1.0, so I assume if N=1000 the square wave would have 1.2s ..
Regards,
IanP
Re: Hardware Delay
So, you mean that is no problem with the code when you using my code? you got change the N=1000 or N=1 on code then run it in practical way? At N=1000 the code i need to wait the pin1.0 with LED blinking very long...what's the broblem??:cry: Is it my hardware problem??
Thanks..
Re: Hardware Delay
That is correct, the software runs well ..
Just to make sure that it also performes with N=1000, can you compile new files with N=1000 and post them?
If you can, replace microcontroller with another 8051-compatibile, and check if the clock frequency is 11,059200 ..
Regards,
IanP
Re: Hardware Delay
I already post N=1000 and N=1 Hex file to you, please try and see...
I only have 89c52 and i am using 11.059M crystal..
Thanks A Lot....
Re: Hardware Delay
I have tried the N=1000 option and the resultant square wave has ≈0.7s period ..
So, more than less it is manageable ..
On the other hand why your 89C52 behaves differently .. I really don't know ..
Regards,
IanP
    Help
