Difference between lumped matching and distributed matching of Rf circuits
APPUARPITA
Newbie level 6
Hi all,
i want to design a MMIC circuit using lumped matching network,operating frequency is at Ku-band( 14GHz) with a bandwidth of 1GHz,can anybody guide me whether lumped matching is a good option? ( as by lumped matching only i am able to reduce the size of the circuit)
What is the basic difference between lumped matching and distributed matching network ?
Which one is better for broadbanding ?
-Lumped Matching is almost impossible @ 14GHz due to many reasons.( self resonance,dissipation factor,etc).
-Distributed elements can also provide wide-band matching.
MMIC designs use almost exclusively lumped element matching. They get away from it since the parasitics on a MMIC integrated circuit are smaller than a similar lumped element matching network in microstrip.
In every case i can think of, lumped element is a better match anyway. Distributed element matching only works over a limited bandwidth due to transmission line effects.
