el00
Member level 5
I have a square wave (output from a mosfet bridge) that swings from -100V to 0V referred to AGND (see picture) at ~60kHz; in some situation the signal has very narrow positive peaks (width of few ns). I need to detect those peaks, since if they go too positive they can destroy mosfets. A threshold of 15V would be OK.
I tried the circuit in figure: when there are positive peaks the capacitor is charged, and when it goes over Vzener + V[D1] + V[opto] then the capacitor is discharged over the opto (with darlington output) and the output generates an edge. However, as soon as the capacitor begins discharge, voltage drops and current quickly goes to zero, so the output of the opto goes down for about 1ns which is very difficult to detect.
Now, the biggest problem is that on the left of the opto I do not have any voltage supply available: is there a way to improve this circuit without using any supply?
Any ideas?
Any ideas?
