ehabzaky
Junior Member level 3
Dear All,
It may be very basic question but I need help to understand it please.
I have a human sensor which simply send 3.3 volts output once a human movement is detected. I'm connecting this output directly to a MCP23S17 to detect this signal and further process it through Raspberry PI. Up to here everything is OK.
I want to put an LED to give visual indication of human sensor action. When I connect the output of the human sensor to an LED with a resistor it was lighting OK but the MCP23S17 no longer detect the signal as per the following diagram. It seems that the current is going through the LED path only.
Could someone guide me how to have both LED working on signal and MCP23S17 detect it?
Regards,
Regards,
