microstrip patch antenna at 900 Mhz design and simulation in ads 2008
umair7
Newbie level 3
my project is"microstrip patch antenna at 900 Mhz design and simulation in ads 2008". Is there any tutorial of this ?I don't have good command on ads2008 ....please helpppp
Try using Google. Usually it helps a lot.
Or you can read Tutorials of ADS on how to design antennas before jumping into a microstrip design.
I learn my design skill by myself using Google and a lot of trial and errors.
Forum won't help to improve your skills, but it's a 2 way street.
Reactions: umair7
    umair7
this tutorial learn u to design microstrip with ADS so for that frequency u should design antenna with bigger size
  • Simulation of a 2.4 GHz Patch Antenna using ADS Momentum.pdf
thks for helping me...............
I have tried the simulation tutorial which you provided. That was really helpful but I am not getting "FAR FIELD" option after setting "3d visualization" in the "radiation pattern" of "Momentum's post processing " option....
