ranaya
hi every1....
I'm gonna implement a data logger which has 8 Analog input channels. my supervisor told me, that voltage input should be able to use for any voltage level, (can read mV and V/ max 25V). So even temperature sensor signal output can be attached to it. User should be able to select the sensor type through the application software.
For mV values, input should be amplified & for max voltage (25V) i have to bring it to 5V (for ADC of MCU).
How can i measure both readings from same analog input ? Do i have to use variable gain controller ?
