ghostridergr
This was my initial code:
My question is this: Is this code synthesible? Or only one element can be stored in each clock cycle?
You can what the types at the final code.
If this code is not synthesible, can you suggest me some changes so as to do it.
I am thinking of those:
insert a flag on my code (so as to know when inp1,inp2 arrays are filled) and then put the loop in a individual process (with no wait so as to run all the time). Then having an if clk'event and inside do the assignment. In this case this is my code:
but as you can see I am getting a fatal error in here. Can anyone help me?
storing: for k in 0 to 10 loop
inside: for l in 0 to 10 loop
sum_of_square_all(k)(l)<=signed(ext(sum_of_square(inp1(k),inp2(l),"000000000000000000000000"),3*N));
wait for 15 ns;
end loop inside;
match(k)<=find_min(sum_of_square_all(k));
end loop storing;
library IEEE;
use IEEE.std_logic_1164.all;
use STD.TEXTIO.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
entity tb_file_landmark is
generic
(N :integer := 8);
port ( clk:in std_logic
end tb_file_landmark;
architecture TB_ARCHITECTURE of tb_file_landmark is
file IN_1_VECTORS: TEXT open READ_MODE is "input_1.txt";
file IN_2_VECTORS: TEXT open READ_MODE is "input_2.txt";
file OUT_VECTORS: TEXT open WRITE_MODE is "output.txt";
--here
type matrix1_t is array(natural range<>) of signed(N-1 downto 0);
type big_matrix is array(natural range<>) of signed(3*N-1 downto 0);
type matrix2d is array (natural range<>) of matrix1_t(0 to 3);
signal sum_of_square_all: matrix2d(0 to 3);
signal inp1,inp2: matrix1_t(0 to 3);
signal a,b: signed(N-1 downto 0):= (others=>'0');
signal match:big_matrix(0 to 3);
signal flag:std_logic:='0';
signal k:integer range 0 to 100:= 0;
signal l:integer range 0 to 100:= 0;
--procedure sum_of_square( signal a,b: in signed(N-1 downto 0);signal previous_sum:in std_logic_vector(3*N-1 downto 0); signal sum:out std_logic_vector(3*N-1 downto 0)) is
function sum_of_square( a1,b1: in signed(N-1 downto 0); previous_sum:in std_logic_vector(3*N-1 downto 0))return std_logic_vector is
variable temp_sum:std_logic_vector(3*N-1 downto 0):=(others=>'0');
variable diff: signed(N-1 downto 0):=(others=>'0');
variable square_diff: std_logic_vector(2*N-1 downto 0):=(others=>'0');
begin
temp_sum:=previous_sum;
diff:=a1-b1;
square_diff:=ext(diff*diff,2*N);
temp_sum:=ext(temp_sum+square_diff,3*N);
return temp_sum;
end sum_of_square;
function find_min(row: in matrix1_t(0 to 3)) return signed is
variable temp_min:signed(3*N-1 downto 0);
begin
temp_min:=row(0);
checking: for t in 1 to 3 loop
if (row(t)<temp_min) then
temp_min:=row(t);
end if;
end loop checking;
return temp_min;
end find_min;
begin
process
variable IN_BUF: LINE;
variable OUT_BUF: LINE;
variable a_var,b_var : bit_vector(N-1 downto 0):= (others=>'0');
variable i,j: integer;
-- variable c_var,d_var : bit_vector(N-1 downto 0):= (others=>'0');
--variable sum_var:std_logic_vector(3*N-1 downto 0):= (others=>'0');
begin
i:=0;
j:=0;
while not ENDFILE(IN_1_VECTORS) loop
READLINE(IN_1_VECTORS,IN_BUF);
READ(IN_BUF,a_var);
a<=signed(to_stdlogicvector(a_var));
wait for 50 ns;
inp1(i)<=a;
i:=i+1;
end loop;
while not ENDFILE(IN_2_VECTORS) loop
READLINE(IN_2_VECTORS,IN_BUF);
READ(IN_BUF,b_var);
b<=signed(to_stdlogicvector(b_var));
wait for 50 ns;
inp2(j)<=b;
j:=j+1;
end loop;
flag<='1';
wait;
end process;
process(clk)
variable row:integer;
variable column: integer;
begin
if (flag='1') then
if (clk'event) then
if ((k<=10) and (l<=10)) then
--############GETTING FATAL ERROR IN HERE##########
k<=k+1;
l<=l+1;
end if;
end if ;
end if ;
end process;
end TB_ARCHITECTURE;
