View RSS Feed
niciki's blog
[Vivado 18.2] IP Packager PCIe4 Missing Interfaces
Rate this Entry
Feedback:
Please leave the comment below.
Is this blog entry helpful or does it need an improvement?
The problem:
In Vivado 2018.2 in the IP Packager when I was trying to make a custom component with mating interfaces to control PCIe4 IP Core, I couldn't do it because in the IP Packager PCIe4 control interfaces were missing, e.g.:
VLNV xilinx.com:display_pcie4:pcie4_cfg_mgmt_rtl:1.0
VLNV xilinx.com:display_pcie4:pcie4_cfg_pm_rtl:1.0
The only option left for me was to connect every signal in all interfaces one by one.
It would be very time consuming and I would lost the auto-propagation interfaces parameters feature, so I decided to find a workaround.
The following pictures visualize the problem:
ID:	147110 Click image for larger version.
ID:	147108 Click image for larger version.
The solution:
To make a workaround I have copied an “interfaces” folder from the PCIe4 IP Core Vivado installation folder to my project:
<path_to_the_Vivado_installation_folder>/Vivado/2018.1/data/ip/xilinx/pcie4_uscale_plus_v1_3/interfaces
I have made modifications to the interfaces as follows:
  • for “*_rtl.xml” files I have added some character, e.g. 'm', at the beginning of the “spirit:busType->spirit:library” parameter value;
  • for other xml files I have changed “spirit:library” value parameter accordingly by adding the same character e.g. 'm' at the beginning of the parameter value.
ID:	147113 Click image for larger version.
Then I have added changed interfaces folder to my project by Settings->IP->Repository.
ID:	147370 Click image for larger version.
Now I can see and use all PCIe4 interfaces in the IP Packager!
ID:	147382 Click image for larger version.
Updated 20th September 2018 at 06:51 by niciki
Tags: None Add / Edit Tags
Categories
Xilinx Vivado Workarounds , Vivado , IP , Interface , PCIe4
Comments
