[SOLVED] XP +-15V DC DC converter not working properly
fouwad
Full Member level 4
Pakistan
hi, i just bought XP's DC DC converter dual output +-15V model name: JTL4024D15
Datasheet: https://www.farnell.com/datasheets/579334.pdf
The problem i am facing is that the output is stable on no load i.e. +15 and -15 but when load is applied to any one of the outputs the loaded ouput drops to 10V and other output rises to 20V, I am unable to understand this phenomenon as DC DC converters are supposed to provide fixed and highly accurate output Voltage, so please anyone do reply me thanks
Did you read the datasheet specification about required minimal load (10%) and cross regulation of dual output types? It's quite normal behaviour of standard DC/DC converters.
yes i am using minimum load of 10% but as i am new in this field of power electronics, can you please elaborate me the concept of cross regulation?
