rogertilman
Newbie level 5
compedklib
I have a compile problem with the microblaze precompiled IP cores 2.0 - 2.1 & 3.0.
I want to simulate the microblaze processor in modelsim 5.7g(full license).
I have created a project in the EDK environment and downloaded it in to my hardware, no problem so far. But when I want to simulate my design in modelsim i get a compatibility problem, it seems that modelsim5.7g can not recognize the microblaze_wrapper file. ModelSim gives me the following error:
# -- Compiling architecture structure of microblaze_0_wrapper
# ** Error: D:/Xilinx/Modeltech_xe/xilinx_lib/EDK_Lib/microblaze_v2_10_a//microblaze/_primary.dat(1): near ";": This version of compiler incompatible with library .dat file
# ** Error: D:/Xilinx/Modeltech_xe/xilinx_lib/EDK_Lib/microblaze_v2_10_a//microblaze/_primary.dat(1): syntax error
# ** Error: D:/Xilinx/Modeltech_xe/xilinx_lib/EDK_Lib/microblaze_v2_10_a//microblaze/_primary.dat: This version of compiler incompatible with library .dat file
# WARNING[1]: microblaze_0_wrapper.vhd(570): No default binding for component: "microblaze". (No entity named "microblaze" was found)
# ** Error: microblaze_0_wrapper.vhd(573): VHDL Compiler exiting
# ERROR: d:/Xilinx/Modeltech_xe/win32xoem/vcom failed.
It is obvious that I have an incompatibility problem between versions, does someone have a solution for this besides a modelsim upgrade. I have tried modelsim version 5.8c, comes with the EDK6.3 & ISE6.3, but still the same problem occours and it's only width the microblaze_wrapper file. The other wrapper files are no problem.
