Xilinx Ise Integration problems
vedpvatsa
Newbie
I have tried a lot to integrate the Xilinx ISE 14.5 System Generator with my matlabR2010 version
But I have been a failure.
Here's the response of my matlab command window
>> hdlsetuptoolpath
??? Undefined function or variable
'hdlsetuptoolpath'.
>> hdlsetuptoolpath('ToolName','Xilinx ISE','ToolPath','C:\Xilinx\14.3\ISE_DS\ISE\bin\nt64\ise.exe')
??? Undefined function or method 'hdlsetuptoolpath' for input arguments of type 'char'.
Warning: Loading model 'xbsIndex' generated with a newer version (7.7) of Simulink
> In load_system at 41
In C:\Xilinx\14.5\ISE_DS\ISE\sysgen\bin\nt\sl_customization.p>sl_customization at 18
In sl_refresh_customizations>call_all at 154
In sl_refresh_customizations at 78
In slcustomize at 4
In simulinkrc at 39
Warning: Cannot find path "C:\Xilinx\14.5\ISE_DS\ISE\bin\nt" in "PATH" environment.
Cannot find path "C:\Xilinx\14.5\ISE_DS\ISE\lib\nt" in "PATH" environment. The libraries
under the path are needed to simulate and netlist designs using blocks from Xilinx System
Generator for DSP blockset.
Cannot find path "C:\Xilinx\14.5\ISE_DS\PlanAhead\bin" in "PATH" environment.
To make sure that your design simulates and netlists with Xilinx blockset as expected it is
required that you start MATLAB using "Xilinx Design Tools\ISE Design Suite 14.5\System
Generator\Sysgen Generator" from All Programs menu under Windows Start button.
Warning: xbsIndex.mdl, line 143: Parameter must be a valid enumeration choice.
In slcustomize at 4
In simulinkrc at 39
If anyone has any solutions for it then I would be extremely thankful to him.
Looks like the Xilinx installation was done incorrectly, or you are trying to run the tools through a command window without having run the settings64.bat file or opened a Xilinx command prompt window. Each of the errors you are showing are that the tools aren't finding the environment variables that match the installation path for the various tools.
