yanqele
Newcomer.
Can somebody please answer two simple questions? I could not find the answer in docs.
The configuration submitted to CoreGen is the most simple one, all defaults, except I need a width of 32 bits and a depth of 4096.
The header generated by CoreGen (VHO file) specifies one input named clk to the core.
Do I have to program that clock? Is it not possible to simply use the 50MHz system clock? And then, how do I connect the system clock to the clk signal? Just a simple permanent assignment (that is, not in a process) ?
Other question: how do I configure with_parity/without_parity? Is parity automatically added to the stated width, or included in the stated width, and then who manages the
parity bit, one per byte I guess, is it automatic or do I have to progam it myself?
Thanks in advance
Thanks in advance
