priestnot
Member level 5
First of all thanks for your time to read this post...
OK I am trying to implement a simple project to test a board with a Xilinx XC2C256 CPLD.
I have managed to create a .ucf file with the Reference Manual page 6.
and then i created a toplevel file to interact with the IO:
As you can see all i have done was to crete a module with all the IO pins Clock and a Button wich i connected like this:
Whem i implement the design i get this error:
Can some one tell me what the problem is? Does it mean i cannot connect a IO to another directly?
Thanks for all the help....
---------- Post added at 19:57 ---------- Previous post was at 19:26 ----------
Alredy solved
NET "SYSCLK" LOC = "38";
NET "A4" LOC = "43";
NET "A5" LOC = "42";
NET "A6" LOC = "41";
NET "A7" LOC = "39";
NET "A8" LOC = "40";
NET "A10" LOC = "34";
NET "A11" LOC = "35";
NET "A12" LOC = "33";
NET "A13" LOC = "32";
NET "A14" LOC = "31";
NET "A15" LOC = "30";
NET "A16" LOC = "28";
NET "A17" LOC = "26";
NET "A18" LOC = "25";
NET "A19" LOC = "24";
NET "A20" LOC = "23";
NET "A21" LOC = "22";
NET "A22" LOC = "21";
NET "A23" LOC = "20";
NET "A24" LOC = "19";
NET "A25" LOC = "18";
NET "A26" LOC = "17";
NET "A27" LOC = "16";
NET "A28" LOC = "15";
NET "A29" LOC = "14";
NET "A30" LOC = "13";
NET "A31" LOC = "12";
NET "A32" LOC = "11";
NET "A33" LOC = "10";
NET "A34" LOC = "9";
NET "A35" LOC = "7";
NET "A36" LOC = "6";
NET "A37" LOC = "5";
NET "A38" LOC = "4";
NET "A39" LOC = "3";
NET "A40" LOC = "2";
NET "B5" LOC = "142";
NET "B6" LOC = "140";
NET "B7" LOC = "139";
NET "B8" LOC = "138";
NET "B9" LOC = "137";
NET "B10" LOC = "136";
NET "B11" LOC = "135";
NET "B12" LOC = "134";
NET "B13" LOC = "133";
NET "B14" LOC = "132";
NET "B15" LOC = "131";
NET "B16" LOC = "130";
NET "B17" LOC = "129";
NET "B18" LOC = "128";
NET "B19" LOC = "126";
NET "B20" LOC = "125";
NET "B21" LOC = "124";
NET "B22" LOC = "121";
NET "B23" LOC = "120";
NET "B24" LOC = "119";
NET "B25" LOC = "118";
NET "B26" LOC = "117";
NET "B27" LOC = "116";
NET "B28" LOC = "115";
NET "B29" LOC = "114";
NET "B30" LOC = "113";
NET "B31" LOC = "112";
NET "B32" LOC = "111";
NET "B33" LOC = "110";
NET "B34" LOC = "107";
NET "B35" LOC = "106";
NET "B36" LOC = "105";
NET "B37" LOC = "104";
NET "B38" LOC = "103";
NET "B39" LOC = "102";
NET "B40" LOC = "101";
NET "D12" LOC = "80";
NET "D13" LOC = "79";
NET "D14" LOC = "78";
NET "D15" LOC = "77";
NET "D16" LOC = "76";
NET "D17" LOC = "75";
NET "D18" LOC = "74";
NET "D19" LOC = "71";
NET "D20" LOC = "70";
NET "D21" LOC = "69";
NET "D22" LOC = "68";
NET "D23" LOC = "66";
NET "D24" LOC = "64";
NET "D25" LOC = "61";
NET "D26" LOC = "60";
NET "D27" LOC = "59";
NET "D28" LOC = "58";
NET "D29" LOC = "57";
NET "D30" LOC = "56";
NET "D31" LOC = "54";
NET "D32" LOC = "53";
NET "D33" LOC = "52";
NET "D34" LOC = "51";
NET "D35" LOC = "50";
NET "D36" LOC = "49";
NET "D37" LOC = "48";
NET "D38" LOC = "46";
NET "D39" LOC = "45";
NET "D40" LOC = "44";
NET "LD2" LOC = "92";
NET "BTN1" LOC = "143";
`timescale 1ns / 1ps
// Company: FEUP/DEEC
// Engineer: Eduardo Sousa
// Create Date: 10:13:45 05/19/2011
// Design Name:
// Module Name: xc2c256_toplevel
// Project Name:
// Target Devices:
// Tool versions:
// Description: XC9500XL toplevel for the xc2c256
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module xc2c256_toplevel
// XC9500XL (xc2c256) toplevel FILE
//[Net pin name],
// System Clock
SYSCLK,
//BTN
BTN1,
// LED2
LD2,
// Expansion connector A:
A4,
A5,
A6,
A7,
A8,
A10,
A11,
A12,
A13,
A14,
A15,
A16,
A17,
A18,
A19,
A20,
A21,
A22,
A23,
A24,
A25,
A26,
A27,
A28,
A29,
A30,
A31,
A32,
A33,
A34,
A35,
A36,
A37,
A38,
A39,
A40,
// Expansion connector B:
B5,
B6,
B7,
B8,
B9,
B10,
B11,
B12,
B13,
B14,
B15,
B16,
B17,
B18,
B19,
B20,
B21,
B22,
B23,
B24,
B25,
B26,
B27,
B28,
B29,
B30,
B31,
B32,
B33,
B34,
B35,
B36,
B37,
B38,
B39,
B40,
// Expansion connector C:
D12,
D13,
D14,
D15,
D16,
D17,
D18,
D19,
D20,
D21,
D22,
D23,
D24,
D25,
D26,
D27,
D28,
D29,
D30,
D31,
D32,
D33,
D34,
D35,
D36,
D37,
D38,
D39,
D40,
// System Clockinput
input SYSCLK;
// BTN
input BTN1;
// LED2
output LD2;
// Interface signals of expansion connector A
// Pin direction must be modified for each application
//A1 GND
//A2 VU
//A3 VDD33
input A4;
input A5;
input A6;
input A7;
input A8;
//A9 XLCLK
input A10;
input A11;
input A12;
input A13;
input A14;
input A15;
input A16;
input A17;
input A18;
input A19;
input A20;
input A21;
input A22;
input A23;
input A24;
input A25;
input A26;
input A27;
input A28;
input A29;
input A30;
input A31;
input A32;
input A33;
input A34;
input A35;
input A36;
input A37;
input A38;
input A39;
input A40;
// Interface signals of expansion connector B
//A1 GND
//A2 VU
//A3 VDD33
//A4 BTN1
input B5;
input B6;
input B7;
input B8;
input B9;
input B10;
input B11;
input B12;
input B13;
input B14;
input B15;
input B16;
input B17;
input B18;
input B19;
input B20;
input B21;
input B22;
input B23;
input B24;
input B25;
input B26;
input B27;
input B28;
input B29;
input B30;
input B31;
input B32;
input B33;
input B34;
input B35;
input B36;
input B37;
input B38;
input B39;
input B40;
// Interface signals of expansion connector D
//D1 GND
//D2 VU
//D3 VDD33
//NOT D4;
//D5 L5
//NOT D6;
//NOT D7;
//NOT D8;
//NOT D9;
//NOT D10;
//NOT D11;
input D12;
input D13;
input D14;
input D15;
input D16;
input D17;
input D18;
input D19;
input D20;
input D21;
input D22;
input D23;
input D24;
input D25;
input D26;
input D27;
input D28;
input D29;
input D30;
input D31;
input D32;
input D33;
input D34;
input D35;
input D36;
output D37;
output D38;
input D39;
output D40;
//Turn BTN1 into reset button
assign SYSRST=BTN1;
//teste para apagar
assign D40=1'b0;
assign D38=1'b1;
assign D37 = D36;
endmodule
assign SYSRST=BTN1;
//teste para apagar
assign D40=1'b0;
assign D38=1'b1;
assign D37 = D36;
ERROR:Cpld:832 - 'D37' is assigned to an invalid location ('48') for this
device. This will prevent the design from fitting on the current device.
'D37' must be reassigned before attempting a re-fit.
ERROR:Cpld:868 - Cannot fit the design into any of the specified devices with
the selected implementation options.
Alredy solved
