Wireless communication between two PIC16F877A using 433MHz TX/RX modules
ponty77
Newbie level 3
Hello Everyone,
I would like to use wireless communication between 2 pic16f887. I use rf 433 mhz module, and i would like controll 2 motor pwm. I use mikroC, and attached the source code. I have a problem with the wireless communication, and how to set txsta, rcsta, baudctlbit. I would like use 9600 baud. If anybody need the mikroC file, I will post it.
Thanks for help.
  • transmitter.txt
  • receiver.txt
Please Zip and post the mikroC PRO Project files.
Thanks for your reply. Here is 2 mikroc project and 1 protheus file with wire communication.
View attachment copter.zip Sorry I forget it :D
Yes, I can. But I need your help in register setting. If I transmit the pwm duty, do you tell me an example ?? And if would like send another data e.g. adc value, or someting, how can I do it ??
Can you instead send PWM duty value (0 - 255) from transmitter to receiver ?
Here is the fixed code but I think the logic of operation is not correct.
Use RC Toy.rar
  • mikroC PRO PIC.rar
  • RC Toy.rar
Thanks for your replying. I will test the code at the weekend, and I will write for you. Thanks for your help.
