i have ps/2 barcode.. and my transceiver is UART capable.. it has 6 channels with the range of 200meters.. how can i interface it with a microcontroller?
the PC2 interface has, apart from ground and Vcc, DATA and CLOCK signals which you can connect two digital input lines of a microcontroller.
You wait for a START bit on the data line, then read the data line as the information is clocked in. Have a look at
you then connect the RF device to a UART for transmission of the information.
