bimsriraj said:what is meant by free space path loss?
.biff44 said:free space path loss is what you get when your transmit and receive antennas are ontop of 300 foot towers with nothing in between but air, and assume no multipath. It is easy to calculate.
Actual path loss, with trees and buildings and reflections, is a much higher number. Unfortunately it is the actual path loss that you deal with in communications networks.
bimsriraj said:.biff44 said:free space path loss is what you get when your transmit and receive antennas are ontop of 300 foot towers with nothing in between but air, and assume no multipath. It is easy to calculate.
no, freespace loss may be due atmopseher is absorbing less signal, so signal will be behaving same as like vaccuum.thats why may be people are calling as free space path loss
A signal behave like a vacuum !!?? Probably we can get even a Black Hole...so signal will be behaving same as like vaccuum
LvW said:May I try to give an additional explanation ?
Of course the answer from BIF44 is correct, but perhaps not easy to understand as it is not a real definition.
An ideal isotropic antenna would emit all the input power P equally in all directions.
Therefore, the portion in "only one" direction from this antenna is the density D:
D=P/4Pi*r² (r=distance). This is something like a spreading effect.
This has to be multiplied with the antenna parameters which involve gain and frequency. As the result the "spreading" effect (which has nothing to do with any kind of attenuation) is lowered and leads to actual "loss" figures.
Atmospheric and other parasitic influences have to be considered separately.
what i mean is signal exactly behave when travelling in a vacuum space.vfone said:A signal behave like a vacuum !!?? Probably we can get even a Black Hole...so signal will be behaving same as like vaccuum
