why we don't use simple diodes to build BGR
nus_lin
Member level 1
dear guys, the bjt used in bandgap reference is actually diodes, so why don't we just use nwell-diodes, or n+p- diodes?
Because BJTs diode-connected are log-linear over a much
wider current range, which is good since you operate
the diodes at discrepant current densities.
here is my friend's comments:
in Wiley Sansens design essentials (slide 165, page 457) :
"A bandgap reference voltage uses a bipolar transistor, connected as a diode. Its current-voltage
expression is then quite accurately given by the exponential. A real pn-junction may have a
coefficient of 1.05–1.1 in front of the kT/q; a bipolar-transistor connected as a diode does not"
---------- Post added at 02:51 ---------- Previous post was at 02:48 ----------
hi, freebird, your answer does not satisfy me, can not explain why simple diode is inferior to bjt in terms of log-linear.
---------- Post added at 02:52 ---------- Previous post was at 02:51 ----------
also according to my friend's comment:
I don't know why the diode should have more variation than the diode connected bipolar, which is actually nothing else than a diode, too
---------- Post added at 03:17 ---------- Previous post was at 02:52 ----------
i figure out a possible explanation.
if we look at their voltage drop, you will see that Vbe(bjt)<Vbe(Nwell diode)<Vbe(N+p- diode), under the same current density. if you look at the serial resistance, bjt should be better than both nwell diode and N+p- diode.
i think beta helps a lot. R_eq_c=R_b/beta, where R_b is the base resistance, R_eq_C is an equivalent resistor in parallel with the resistance of the collector itself, which should be much smaller than R_b, due to the large area of collector.
