imett
Junior Member level 1
Hi to everyone
i've a question for a skilled user, i've to design a superheterodine (100MHz 2GHz) receiver with an up conversion at 3GHz ad one down conversion at 50MHz . I've to use two VCO from minicircuits but i've read that it be used with pll to have a stability.
So PLL limited my sweep time,and complited the design and i don't need much precision or stability on the frequency of my VCO's.
I've to use pll when i use a mixer to achieve a low freq vco with high span , example for a sweep output signal 100MHz to 1500MHz RF 1.5GHz-3GHz (variable) LO 1.6GHz (fixed) so IF 0.1-1.5GHz.?
thanks
thanks
