Why is the circuit behaving so????
shaikss
Full Member level 4
I used SPDT switch to enable/disable one of the topologies.
When I tried yesterday with single stage of rectifier topology, it was working fine.
Today, I simulated the similar concept with multi-stage rectifier for both topologies. I see some strange results.
Can you pls explain why there is change in behavior of signal?
In this zip file, 1.png is the waveform which I observed for the SPDT switch with no load.
multi_1.png is the plot when load (rectifiers) are present. multi_2.png is the circuit diagram of complete design and the last fig is the zoomed version of SPDT switch.
Request you to pls help me.
  • multi.zip
