kvn0smnsn
Junior Member level 2
With the help of people on this forum, I was able to build a module that takes as input a six-bit (Dividend), and outputs a three-bit (Quotient) that is the result of dividing (Dividend) by 10, and also a four-bit (Remainder) that is the remainder of that division. Then I wanted to test it by dividing every third integer from 0 to 63 by ten, and making sure I got the right result. I also threw in 6'b000001 and 6'b111110. So the two files I entered into EDA Playground are:
and:
My results are:
This appears to be running two nanoseconds and then stopping. Why isn't the ($finish) causing it to stop after 24 nanoseconds, since I've got twelve statements before it with a (#2) right before each of them?
module FullAdder( cOut, sum, aOp, bOp, cIn);
output cOut;
output sum;
input aOp;
input bOp;
input cIn;
assign cOut = aOp & bOp | aOp & cIn | bOp & cIn;
assign sum = aOp ^ bOp ^ cIn;
endmodule
module Mux #( nmBits = 1)
( result, control, hgVal, lwVal);
output [ nmBits-1:0] result;
input control;
input [ nmBits-1:0] hgVal;
input [ nmBits-1:0] lwVal;
genvar bt;
generate
for (bt = 0; bt < nmBits; bt = bt + 1)
begin
assign result[ bt] = control ? hgVal[ bt] : lwVal[ bt];
end
endgenerate
endmodule
module AddVector #( nmBits = 1)
( sum, aOp, bOp);
output [ nmBits :0] sum;
input [ nmBits-1:0] aOp;
input [ nmBits-1:0] bOp;
wire [ nmBits :0] carry;
assign carry[ 0] = 1'b0;
assign sum[ nmBits] = carry[ nmBits];
genvar bt;
generate
begin
FullAdder fa( carry[ bt + 1], sum[ bt], aOp[ bt], carry[ bt]);
end
endgenerate
endmodule
module DivByTen( quotient, remainder, dividend);
output [ 2:0] quotient;
output [ 3:0] remainder;
input [ 5:0] dividend;
wire [ 6:0] sum40;
wire [ 6:0] sum20;
wire [ 5:0] sum10;
wire [ 5:0] result40;
wire [ 4:0] result20;
wire [ 3:0] result10;
AddVector #(6) av40( sum40, dividend, 6'b011000); // Subtract 40.
AddVector #(6) av20( sum20, result40, 6'b101100); // Subtract 20.
AddVector #(5) av10( sum10, result20, 5'b10110 ); // Subtract 10.
// For each mux, pass through the least significant bits of the sum if the
// most significant bit is high, which indicates the subtraction is positive;
// otherwise pass through the value before the subtraction.
Mux #(6) mx40( result40, sum40[ 6], sum40[ 5:0], dividend);
Mux #(5) mx20( result20, sum20[ 6], sum20[ 4:0], result40[ 4:0]);
Mux #(4) mx10( result10, sum10[ 5], sum10[ 3:0], result20[ 3:0]);
assign quotient[ 2] = sum40[ 6];
assign quotient[ 1] = sum20[ 6];
assign quotient[ 0] = sum10[ 5];
assign remainder = result10;
endmodule
module t_DbtAvMx;
reg [ 5:0] dividend;
wire [ 2:0] quotient;
wire [ 3:0] remainder;
DivByTen dbt( quotient, remainder, dividend);
initial
begin
dividend = 6'b000000;
#2 dividend = 6'b000001;
#2 dividend = 6'b000011;
#2 dividend = 6'b000110;
#2 dividend = 6'b001001;
#2 dividend = 6'b001100;
#2 dividend = 6'b001111;
#2 dividend = 6'b010010;
#2 dividend = 6'b010101;
#2 dividend = 6'b011000;
#2 dividend = 6'b011011;
#2 dividend = 6'b011110;
#2 dividend = 6'b100001;
#2 dividend = 6'b100100;
#2 dividend = 6'b100111;
#2 dividend = 6'b101010;
#2 dividend = 6'b101101;
#2 dividend = 6'b110000;
#2 dividend = 6'b110011;
#2 dividend = 6'b110110;
#2 dividend = 6'b111001;
#2 dividend = 6'b111100;
#2 dividend = 6'b111110;
#2 dividend = 6'b111111;
#2 $finish;
end
always @( quotient, remainder)
begin
$display
( "time: %3t, dvdnd: %d, qtnt: %d, rmndr: %d."
, $time, dividend, quotient, remainder);
end
endmodule
Chronologic VCS simulator copyright 1991-2021
Contains Synopsys proprietary information.
Compiler version S-2021.09; Runtime version S-2021.09; Nov 20 13:40 2022
time: 0, dvdnd: 0, qtnt: X, rmndr: x.
time: 0, dvdnd: 0, qtnt: 0, rmndr: 0.
time: 2, dvdnd: 1, qtnt: 0, rmndr: 1.
time: 2, dvdnd: 1, qtnt: X, rmndr: 1.
time: 2, dvdnd: 1, qtnt: x, rmndr: x.
$finish called from file "testbench.sv", line 34.
$finish at simulation time 48
V C S S i m u l a t i o n R e p o r t
Time: 48 ns
CPU Time: 0.440 seconds; Data structure size: 0.0Mb
Sun Nov 20 13:40:26 2022
Done
