niliany
Newbie level 1
I wanna to simulate a circuit with proteus,but it says:
SIMULATION LOG
Design: D:\Backup\work\Keil\My_Pro_Keil\DigitalTem\51MCU_CPLDV2.0.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author: <NONE>
Created: 07/02/27
Modified: 09/04/10
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
WARNING [ROOT10] : Parameter <INVERT> not defined in INVERT of U1.
WARNING [ROOT10] : Parameter <INVERT> not defined in INVERT of U2.
Partition analysis...
Simulating partition 1 [3EDA532D]...
PROSPICE Release 6.9 SP4 (C) Labcenter Electronics 1993-2006.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
ERROR: [U12_I1] D1WIO.DLL failed to create DSIM model for primitive type 'D1WIO'.
Reading SPICE models...
Building circuit...
Warning: Net #00082 has no DC path to ground.
Check pins: X1_CS-2, X1_L-1
Warning: Net #00083 has no DC path to ground.
Check pins: X1_L-2, X1_R-1
Warning: Net #00104 has no DC path to ground.
Check pins: U13-X2, U13_ADC#0001-A, X0B39721C#4-*, X0B396970#0-*, X1-1, X1_CP-1, X1_CS-1
Warning: Net #00105 has no DC path to ground.
Check pins: U13-X1, U13_ADC#0002-A, X0B39721C#3-*, X0B396970#1-*, X1-2, X1_CP-2, X1_R-2
Instantiating SPICE models...
Real Time Simulation failed to start
Totaliters=0, Totalsteps=0, Goodsteps=0, Badsteps=0
Simulation FAILED due to fatal simulator errors.
Who can tell me what's with that?
Many thanks!
Added after 1 minutes:
How to solve this problem ?
SIMULATION LOG
Doc. no.: <NONE>
Revision: <NONE>
Author: <NONE>
Created: 07/02/27
Modified: 09/04/10
Build completed OK.
Linking netlist...
Reading netlist...
Building circuit...
Many thanks!
