which port i need to use in thia planar monopole antenna???
slteoh
**broken link removed** Uploaded with ImageShack.us
anyone know how to simulate this antenna???which port i have to use??
and what is mean by feeding strip??Is it using that for waveport??
hi deer
for this antenna better u use SMA and for simulation u should use wave port in hfss11
and for more information u can read this book
Broadband Planar Antennas Design and Applications by Zhi Ning Chen and Michael Y. W. Chia
in chapter 5 u can find this antenna and in chapter 3 u can find feeding by microstrip
Reactions: slteoh
    slteoh
i am using cst so how to create a sma connector for the simulation.Thanks for ur help!!!
Reactions: yasap
    yasap
hi
create a hole in u antenna ground page with r=1.6 and then design a pin in center of it with r=0.6 and the height of pin h=.5mm(1mm) + H which H the height of u ground page and u pin u been .5mm(1mm) upper than u ground like the fig u attach
its work!!!thanks very much
    V
