Which is the best programmer for programming microcontrollers?
bjkbj701019
Junior Member level 1
Hi.
Someone pls help me!!
which is the best programmer for programming microcontrollers? Warp-13?
Thank You
Re: help warp-13a?
Try winpic800
Original site **broken link removed**
Working with plenty hardware.
Re: help warp-13a?
The Warp-13a PIC programmer is identical to Microchip's PICSTART Plus PIC programmer as far as all communication protocols are concerned. MPLAB considers the Warp-13a to be a PICSTART Plus and as such there is no separate software to install. Getting the Warp-13a to work with MPLAB may be as simple as a mouse click.
winpic800 no work!
Re: help warp-13a?
bjkbj701019 said:
Hi.
which is the best programmer for programming microcontrollers? ...
Thank You
i think JDM is a good choice if u r in serial port programmers, one like this , all 40-8 pin PIC supported by a single ZIF socket and a single switch, PCB layout is also there **broken link removed**
the schematic :
