what is S/L guardring?
ieok
There is a rule about the pad as below:
Max pad opening space to nearest S/L guard ring =xx
Min pad opening space to nearest S/L guard ring =yy
1. what is the S/L mean for?
I added a guardring by G short cut command around the GSSG pads. The distance is less than yy but DRC is passed...
2. Do we need to add guardring around pads? any reason to do so? pls advise.
I suspect "S/L" stands for substrate/latchup, which is what guardrings are supposed to help prevent.
I cannot explain your observed DRC issue except to wonder if the rule is from PO-to-active, or PO-to-contact. It could make a difference.
The better practice at my company is to always surround pads with guardrings. Usually the ESD device (associated with the pad) and the pad are both surrounded with the same ring.
Hastings ("The Art of Analog Layout") has quite a bit to say about guardrings and their role in latchup prevention.
