b4bb4ge
Full Member level 2
- Joined
- Feb 28, 2008
- Messages
- 128
- Helped
- 30
- Reputation
- 60
- Reaction score
- 16
- Trophy points
- 1,298
- Location
- Colorado, USA
- Activity points
- 2,050
What is considered the "farfield" of an array of antenna elements. I realize that the Far Field of an element is > 2D^2 / lambda; where D is the largest dimension of antenna. But in an array of antennas is this the size of a single element or the size of the array it'self?
I realize the "farfield" is when the EM wave looks planar, therefore you would think that a more directive antenna would have a planar EM wave closer to the aperture because it is more directive, but if you use the entire array as "D" then the farfield could be quite far away?
I have looked through Balanis' and Johnson's books with no luck.
Thanks for your help,
Babbage
Babbage
