what is a low inductance capacitor?
AbrarAhmad
Newbie level 1
what does inductance mean in a capacitor?
Suggest any low inductance capacitor for my low inductance coil i want to pass a pulse of nano second duration through my coil.
Any suggestion will help me a lot.
Every electronic device designed for a specific purpose has intrinsic ( parasitic ) properties. For instance, an Electrolytic capacitor is composed by a twisted thin and long metallic plate wrapped around it axis, so that exhibits an undesirable inductance behaviour, particularly noticed at higher frequencies.
All plastic film caps are inherently low inductance. Some better than others with very low ESR. The abbreviations for popular plastic caps are; PTFE, PU, PE, PS. They are often self-healing as well.
The self resonant frequency of the coil and cap (SRF) must be >> 300MHz to pass 1ns rise time and much higher if this is the pulse width
For Rf caps using special Ceramic under 47 pF are used but not rated for high voltage like plastic. (Murata)
I prefer Polyurethane caps from Epcos / Panasonic.
Avalanche mode sparks can also be passed with small gaps which have sufficient low breakdown gap (1kV/mm) suitable for AC, but latch under DC with sustained current.
Pls supply schematic and photo.
