what happens if i give a weak 0 to a not gate;what would be the strength of output be
kaushikrvs
Member level 5
and what would be the case if a supply 1 and a weak 1 are inputs to an and gate ? what would be the output strength and logic?
I'm assuming you are talking about a Verilog description. Strengths of the inputs do not affect the strength of the output of logic primitives gates. Only the MOS and tran primitives pass strength.
check dave's answer. signal strength is never used when writing verilog in RTL form.
