What does this parameter on a motor's nameplate mean?
powersys
Advanced Member level 1
Hi...
Found a very old brushed DC shunt machine. The nameplate of the motor is attached. The given RPM on the nameplate is RPM: 750/2250. Does it mean the rated speed is 750rpm or 2250rpm? Or, do you have other opinon?
Thank you very much
Without a switching option, e.g. a variable exitation, the specification doesn't make sense.
Our initial guess is the rated speed is 750rpm, and the 2250rpm is the maximum rpm the motor can be driven. I really have no idea... :(
My guess would be the load/no load RPM.
Has it a gearbox or adjustable pulley on the output? One speed is exactly 3 times the other.
If it works you could try measuring it.
Keith
That's true that one speed is exactly 3 times the other. May be it was modified in the past but currently it has no gearbox or adjustable pulley. It's still working at the moment, and it's used as a "passive" load (i.e. a generator) to test a permanent magnet brushless motor. At the moment the system is driven at speeds less than 750rpm. I wish to drive the system up to 1500rpm or higher and am worried the brushed DC shunt machine will be damaged (mechanical failure) at 1500rpm.
