What are these "pink lines" in Cadence schematic editor
DoYouLinux
Hi all,
I just managed to get these strange pink lines on my schematic editor by touching some keys on my keyboard accidentally (see attached picture).
What are they and how can I remove them ???
Thanks a lot,
DYL :D
These look like residual "flight lines" from some earlier
incarnation of the schematic, now unrelated to current
componentry. You could look at the bindkey list for any
keys that look like they pertain to layout synthesis,
draw-flight-lines, etc. and then for its inverse. I do not
let the computer do my floor planning so I never make
use of those features, but I recognize them.
You might also just determine which layer in the DRF these
linea are, and turn it back off. Though it may be one that
is not on the "valid" list, and need you to dig deeper.
Can u zoom into the pink lines.. there could be some objects at hose points which are connected..
This is Check Label Attachment(when you type "h" on your keyboard you will see this popup, you can then select none to remove all the pink lines.
