What are the specifications of opamp design for bandgap?
Re: opamp design for bandgap
kwkam said:
I suggest you check the unity gain bandwidth. If the feedback is not fast enough. The bandgap will oscillate.
How much should the unity gain bandwidth be?
thanks.
(1)how much the “low offset drift” should be?
(2)And what about the input offset voltage? 1mv?5mv?and others?
(3)how to consider noise? add some noise on the vdd? or add a inductor such as 5n to the opamp power supply?
(4)what about the slew rate of the opamp used in bandgap?10v/us? or others?
high gain>70db , phase margin>65C ,and bandwidth<10~20K over your interested temperature .
hope it helps.
open loop gain ,stability, noise and input offset voltage.
low offset opamp and high gain OTA
bsrivastava Posted: 26 Nov 2005 10:17 Post subject: Re: opamp design for bandgap
ICMR of the op-amp should be close to the cutin voltage of the p-n junction diode.
According to bsrivastava,the ICMR of the op-amp should be close to the cutin voltage of the p-n junction diode?
Would any one explain,if ICMR is less than the cutin voltage of the p-n junction diode,what would be the problem?
